heyboer 784-103 secondary wire colors
All about iron and copper.
guilds100
Post by guilds100 » Tue May 26, 2009 4:39 pm
I have a 784-103 heyboer that i've heard for a couple of years and am installing it on a jtm 45 build. I cant find the spec sheet for it. I was able to use my multimeter to figure out the primary side. The secondary has yellow, orange, green and blue. If i compare notes to other transformers, the blue would be the ground. I figure id ask for a second, (or third) opinion before hooking it up.
Finished amps --> Metro JTM45, Champ, Deluxe, Bandmaster, 1974x
Still Debugging --> Metro 50, Trainwreck Express
Re: heyboer 784-103 secondary wire colors
Post by Flames1950 » Tue May 26, 2009 4:58 pm
I thought it was Blue - Common, Yellow - four ohm tap, green - eight ohm tap, and orange - sixteen ohm tap. At least that's how my first JTM45 Metro build was wired.
guilds100
Post by guilds100 » Wed May 27, 2009 9:52 am
Thanks for the reply. I didnt want to start off with a built in problem.
