Please help to identify the wires of the Marshall OT
All about iron and copper.
kochev
Post by kochev » Sat Jun 19, 2010 3:41 pm
Here is the Output trafo from Marshall Master PA 1973 .
Please help to identify the wires.
Experimental setup:
The results - secondary :
Black - Brown 1,5 V
Black - Yellow 0,6 V
Black - Green 1,5 V
Brown - Yellow 2,15 V
Brown - Green 3 V
Yellow - Green 0,85 V
Which wire is for ground and 4 , 8 16 ohms ?
flemingmras
Re: Please help to identify the wires of the Marshall OT
Post by flemingmras » Sat Jun 19, 2010 7:06 pm
kochev wrote:Here is the Output trafo from Marshall Master PA 1973 .
Experimental setup:
Black - Brown 1,5 V
Black - Green 1,5 V
Brown - Green 3 V
The color code on that xformer follows the standard Marshall color code for a 100 Watt Dagnall based on my calculations of your measurements -
Brown = Common (goes to ground)
Black = 4 Ohm
Yellow = 8 Ohm
Green = 16 ohm
White = Primary Center Tap
Red = V4/V5 Plate
Brown = V6/V7 Plate
Primary Zp-p = 1.7K
kochev
Post by kochev » Sun Jun 20, 2010 1:24 am
Тhanks a lot !
flemingmras
Post by flemingmras » Sun Jun 20, 2010 1:32 am
kochev wrote:Тhanks a lot !
Also should note that with that particular primary phasing, the grid of V4 and V5 should be fed from the 82K side of the phase inverter while V6 and V7's grid should be fed from the 100K side of the phase inverter.
