Bias Wire not needed...Ground it or put a heat shrink ?
All about iron and copper.
David_Well
Post by David_Well » Sat Jul 24, 2010 11:48 am
I bought a MM PT with a Bias wire. I don't need this wire.
Simple, Should I Ground the Bias wire or just put a heat shrink and not use it.
Thanks.
flemingmras
Re: Bias Wire not needed...Ground it or put a heat shrink ?
Post by flemingmras » Mon Jul 26, 2010 2:00 pm
David_Well wrote:I bought a MM PT with a Bias wire. I don't need this wire.
Thanks.
If you're sure that it's a bias wire, insulate it...DO NOT GROUND IT!
Which MM PT is it?
David_Well
Post by David_Well » Mon Jul 26, 2010 9:15 pm
The MM Pt is the FPD-20M
I gonna shrink it
I don't use it cause i built a Class A Amp and I order a Single ending MM OT witch is SE-5K-MM
