Help Wiring CT 40-18046 LD PT 12,000 Series
All about iron and copper.
terrykoski
Post by terrykoski » Sat Dec 21, 2013 6:55 pm
HI,I need help wiring a PT Classic Tone for my 12,000 Plexi Kit.
Wires are:
Com: BLK......... RED
100V=WHT....... RED/YEL 350 V CT @290mA
120V=BRN........ RED
200V=BLU........ GRY 98V @50mA
230V=ORN........GRY
240V=VIO.........GRN
....................GRN/YEL 6.3 V @ 7A
What colors to what pins do they solder too on the power tube section?
Power cord, I am sure connects some how in here? Which are ground? Which go to the fuse holders?
Anyone build a 12,000 series and used Classic Tone Irons have a picture I could reference?
Tried cross referencing drawings but everyone uses different Irons and I'm STUCK :help:
vh junkie
Re: Help Wiring CT 40-18046 LD PT 12,000 Series
Post by vh junkie » Thu Dec 26, 2013 3:26 pm
This fellow built one with the 40-18046
http://forum.metroamp.com/viewtopic.php?f=44&t=35856
You should start a build thread in the 12series forum.
Post pics or diagrams of how you intend to connect each wire. The folks there will be happy to check it for you.
- Gunny Highway
rgorke
Post by rgorke » Thu Dec 26, 2013 5:39 pm
vh junkie wrote: You should start a build thread in the 12series forum.
Yeah, there are crickets down there....
Strat78
Post by Strat78 » Fri Dec 27, 2013 10:39 pm
terrykoski wrote:HI,I need help wiring a PT Classic Tone for my 12,000 Plexi Kit.
Wires are:
230V=ORN........GRY
black wire goes to Maines fuse. White wire from power cord goes to the other end of the maines fuse. Brown goes to power switch. Black wire from power cord goes to other end of power switch. Green wire from power cord goes to ground. The two red wires go to the standby switch, the CT goes to the the negitve side of the first maines cap then to the possitve side of the seconed maines cap. Twist the two grey wires and have one go to the bias resistor on the board and the other grey wire to grnd (grnd lug #3 if you are using the Larry grnd method). Green wires to pin 2and 7 of V7. The grn/yel wire goes to grnd (all the way over to grnd lug #1 if using Larry grnd).
Use this layout for reference:
http://forum.metroamp.com/download/file.php?id=3877" onclick="window.open(this.href);return false;
http://www.classictone.net/40-18046.pdf" onclick="window.open(this.href);return false;
If you can make any sense with what I wrote make sure you double check with other sources before wiring it up.
terrykoski
Post by terrykoski » Sat Dec 28, 2013 9:13 pm
Thanks so much Strat78 for the reply, you were spot on. Over the last couple days I had figured a few wires out. Like you suggested, I double checked everything. So at least for now I stopped tripping the breaker in the house when just plugging it in. Lol
