JTM 100 PT help
All about iron and copper.
Re: JTM 100 PT help
Post by Flames1950 » Sun Sep 26, 2010 9:58 pm
If you have to replace that PT, I'd go with Marstran long before MM anyway. :wink:
If you've got the old JMP style selectors with the plugs, do you have any alligator clip leads to short it with to be sure it's not the issue?
Seems like if the PT went, one winding or the other on the secondary side would still work. If the primary side went it would be DOA, but tht doesn't seem likely unless the wrong value fuse was in place.
axeman
Re: JTM 100 PT help
Post by axeman » Sun Sep 26, 2010 10:06 pm
Good Luck :wink:
axeman
Re: JTM 100 PT help
Post by axeman » Sun Sep 26, 2010 10:09 pm
Flames1950 are you going to the amp show? in L.A? I think I owe you a beer from 2 years ago.
Re: JTM 100 PT help
Post by Flames1950 » Sun Sep 26, 2010 10:43 pm
I wish. I could use a cold one.
axeman
Re: JTM 100 PT help
Post by axeman » Sun Sep 26, 2010 10:50 pm
One? I know what you mean. You helped me with my 45/100, I had the primaries backwards.
