****** Audio 2" Drake OT color codes? MightyMike?
All about iron and copper.
5150loveeddie
Post by 5150loveeddie » Tue Oct 31, 2006 7:00 pm
rockstah wrote:
5150loveeddie wrote:
rockstah wrote:its not the same as his 1.5 OT? hmmm
Nop
Ok have it:
Orange is ground (speakers)
Yellow:4ohms
Green:8ohms
grey:16ohms
red/white: primaries
brown?: CT I guess
so the 1.5 is
black 4 ohm
yellow 8 ohm
green 16 ohm
brown ground
red and brown with white stripe primaries ( red to v4 & v5 brown with whiet stripe to v6 & v7
white goes to the main board where choke and fuse are.
is that how yours is wired up?
Chris's 1.5": Brown: common, ground, black 4ohms, yellow8ohms, green16ohms
Primaries are RED/BROWN (pins3) NOT WHITE for the 1.5", THATS for the DRAKE ONLY, be carefull people.......
MArk you have a brown and white stripes you?
CT is white.........yes...
DRAKE had different color code then Dagnall had that is why Chris's are different.....
rockstah
Post by rockstah » Tue Oct 31, 2006 7:09 pm
wait a minute here - this is my ****** 1.5 OT- sorry no brown and white stripe - this is how i wired it up - take a look. (the brown and red wires you see twisted go to the output tubes. )
Billy Batz
Post by Billy Batz » Tue Oct 31, 2006 7:32 pm
Flames1950 wrote:
Billy Batz wrote:Andy I think youd be really into an early 67 style. If not sell me that OT.
Well I'm hell bent on building the eight-cap black flag version of a '67. Just have to iron out details with the rectifier wiring.......got some of the parts details lined up with George (scrapped the tube-recto 50-watt project again!!!)
Brian Wallace knows how to do it. I thought about doing that 67 setup but I said the hell with it. The only thing your really changign is filtering. how much can that parallel bridge effect the tone really? But for nuts like you. Just having a clone that none has ever done will be a selling point. Incidentaly wasnt the 1202-119 the earler 2" EL34 taht would be in those amps? Whats cerrems?
Id love to hear what you think of that amp tho.
rockstah
Post by rockstah » Tue Oct 31, 2006 7:34 pm
rockstah wrote:wait a minute here - this is my ****** 1.5 OT- sorry no brown and white stripe - this is how i wired it up - take a look. (the brown and red wires you see twisted go to the output tubes. )
rockstah
Post by rockstah » Tue Oct 31, 2006 7:41 pm
man dont tell me i wired this wrong! F&^K!
Post by Flames1950 » Tue Oct 31, 2006 8:02 pm
Mark, yours should be fine.....mine is the Drake clone with a different color code than your Dagnall clone. Chill.......chill........ :wink:
rockstah
Post by rockstah » Tue Oct 31, 2006 8:04 pm
Flames1950 wrote:Mark, yours should be fine.....mine is the Drake clone with a different color code than your Dagnall clone. Chill.......chill........ :wink:
i cant till i hear form JP or ****** at this point!
5150loveeddie
Post by 5150loveeddie » Tue Oct 31, 2006 9:26 pm
Your OK, PERFECT
JF :wink:
5150loveeddie
Post by 5150loveeddie » Tue Oct 31, 2006 9:30 pm
Nop
Ok have it:
Yellow:4ohms
Green:8ohms
grey:16ohms
brown?: CT I guess
so the 1.5 is
black 4 ohm
yellow 8 ohm
green 16 ohm
brown ground
Where is that wire you mention here??? :?
rockstah
Post by rockstah » Tue Oct 31, 2006 9:37 pm
is it right?
5150loveeddie
Post by 5150loveeddie » Tue Oct 31, 2006 10:29 pm
yep
rockstah
Post by rockstah » Tue Oct 31, 2006 11:03 pm
nice. :)
5150loveeddie
Post by 5150loveeddie » Wed Nov 01, 2006 3:59 pm
With ****** you have to know your color codes for each type, he uses the same ones as the old irons, even his kt66 OT has only 16 and 8ohms the other wires is to connect to some PA or something he told me not to use it!!!!
Post by Flames1950 » Wed Nov 01, 2006 4:16 pm
5150loveeddie wrote:With ****** you have to know your color codes for each type, he uses the same ones as the old irons, even his kt66 OT has only 16 and 8ohms the other wires is to connect to some PA or something he told me not to use it!!!!
He doesn't bury the 100 volt tap? Brian at Marstran will leave it in on some models but have it buried in the bells so you can't play with it and cause mucho trouble. :lol:
5150loveeddie
Post by 5150loveeddie » Wed Nov 01, 2006 4:24 pm
NOP, well not on the one I have, almost stuck it on the 4ohms terminal :? :oops:
