Orange OR120
- Guitar Adjuster
Orange OR120
Any one know who made the PT and OT for these amps? It's a 70's model OR120.
- Brian Wallace
- Supporting Advertiser
- Guitar Adjuster
- Brian Wallace
Yes and I am doing a teardown on a Parmeko OT as we speak.
- (67.63 KiB) Downloaded 2371 times
- Wicksy
That'll be from an old pix only or120. They used laydowns in those days with the transition about '73 to the Parmeko standups. Very well made iron. Theres a place called PRL in Hudderfield, UK that made the iron for Matamp. I got a replacement OT for a GT-120 i'm restoring. Pretty much the same specs.
Simon
- Brian Wallace
- Guitar Adjuster
- Wicksy
- Guitar Adjuster
- Brian Wallace
- Guitar Adjuster
It's a 1974 version, it's had the original circuit board pulled out and another type of amp installed (Not an Orange any longer). From what I gather it has the original PT but the OT was replaced back in 94 with who knows what? Do you know the B+ for this PT?Brian Wallace wrote:I don't know about the MPT-100. What do you think Wicksy?
How about some inside shots so I can see the solder joints?
Here are some scarry ass gut shots!!!
http://s43.photobucket.com/albums/e397/ ... 2/?start=0
- Wicksy
For a '74 amp (are you sure its a '74? Serial number should be 11xxx ish).
The PT is definitly changed...likely a MM version. Should be delivering ~500V B+ without tubes installed.
The best way to tell if the OT is legit is if the secondary tap wires are twisted ie each tap has two wires together. It looks ok. As for your circuit board, do you know if it is even a correct Orange circuit in there? Or did the tech remake the PCB? I had to do this with a Matamp GT-120 board. The old 70's PCBs are well known for trace lifting.
Heres the board i made for the Matamp:
Simon
- Wicksy
I had a look at your pics...good news is thats the right OT, bad news is i dont think its an Orange anymore
Looks like the FAC isnt working (or exists for that mater) The FAC should be a six way switch with various caps attached to it. Its a variable high pass filter essentially.
I'd advise having it rebuilt. Theres a guy call Rubb over at the Plexi Palace who might be able to help with a PCB template for etching. Then its a matter of populating the board and re-assembling the amp. I can post up some pics of what it should look like inside if you want.
Simon
