Power transformer smoking!
Ok....heres what i have done. I replaced some of the cf resistors on my JTM45 board with NOS CC. All was well until I fired her up for biasing and testing. Did so and blue fireworks from rectifier, red plating, then fuse blown. Ok, checked for accidental grounding mess ups and such. couldnt find a thing. I then removed all tubes and started testing voltages. Severely high voltages on pins 4 and 6 on rectifier. then smoke from PT. I am assuming it has shorted out. Any ideas...Anyone?
If all you did was replace the input resistors, the mixers and V1 plate resistors you would not have needed to rebias and you would not have been able to create any PT mischief.
Did you do anything else to teh amp at the same time, left some swarf or solder around the place, replaced tubes etc.
Your mains fuse should have gone to protect things first if wired correctly, the HT fuse protects the system downstream of where your problem appears to be. I agree with Bluze I cannot make much out from the pics you have posted.
Could you do some close ups of the PT, filter cap and switch arrangement.
Either way a smoking PT is bad news, as I said if your fuse is the correct size and rating the mains fuse should pop.
Here a closer look at the power. I swear all I did was change some resistors and rotate some of the coupling caps so foil end sits towards tubes. , ohh, and did replace the diode, I have checked that and it checks out perfectly with a DMM. I checked to make sure nothing is grounded that shouldn't be. I've kinda narrowed it down to either a bad rectifier, or there was somthing inherently wrong with the transformer from the get go, just picked a long time to show its dark side. I did have the wrong mains fuse in (4amp), so that why it didnt' blow. I'm just dumbfounded.
- (848.8 KiB) Downloaded 37 times
That was the correct 500ma fuse. It did bust some fused right out of the gate...but that evened out. Yep, she sounded like angels since the beginning. I tested the rectifier tube, It is now shorted, but that could have happened during the fireworks a few days ago. So I have to say the issue is indeed the tranny. but I wont know that until i get a new one.
