TSL PT ? ? help
All about iron and copper.
jerrydyer
TSL PT ? ? help
Post by jerrydyer » Mon Mar 03, 2008 12:10 am
what trans does the triple super lead take for PT thanx..same as 900 ?
vids.
jerrydyer
Post by jerrydyer » Mon Mar 03, 2008 4:50 pm
does anyone know where I can get a replacement for this amp tanx
vids.
jasonp
Post by jasonp » Wed Mar 05, 2008 6:38 pm
korg of marshall usa.
I believe it might be the same as the 900's.
You could contact Heyboer as if you give them the voltage readouts of the trannie and size/type they could tell you if it would work on not. I've talked to them before and they are very helpful. Also Hammond makes a 900 tranny just a FYI.
2308to
Post by 2308to » Mon Apr 28, 2008 11:14 am
jerrydyer wrote:does anyone know where I can get a replacement for this amp tanx
Call Korg USA @ 631-390-6500 then go to customer service. If you don't have an account with them, I'm not sure if they will sell to you but I know that they will tell you where you can purchase it. It use to be Parts is Parts but that was a few years.
The Korg USA part number for the TSL100 power transformer is TXMA00061 BTW, it is not the same as the JCM900 series PT.
planetjimi
Post by planetjimi » Mon Apr 28, 2008 11:24 am
Wouldn't any 100 watt power transformer made for el34's work? If not can someone explain?
2308to
Post by 2308to » Mon Apr 28, 2008 12:47 pm
planetjimi wrote:Wouldn't any 100 watt power transformer made for el34's work? If not can someone explain?
Yes, but more modifications would be needed. The TSL100 Power Transformer also has a separate winding for the LT, +-15 for the opamps, relay/optos switching circuit. This is not typical on standard 100 watt Tube power transformers. Also since the TSL's PT is Z mount, putting any old transformer becomes more labor intensive. This is ok if you are doing all of this on your own personal amplifier. If you are repairing an amplifier for someone else, then labor becomes an issue$$ :wink:
planetjimi
Post by planetjimi » Mon Apr 28, 2008 1:05 pm
Oh, I get it .. the extra stuff. Thanks!
