Post
by shakti » Sun Apr 26, 2009 2:52 pm
There were several different power transformers used over the years that original JTM45s were made (1962 - early 1967), so they probably did vary quite a bit. However, after things became a little more standardized, when Marshall had their own transformers made by Drake, the specs for the 1202-55 power transformer is around 450VDC B+. But even those did probably vary a bit. Typically transformers are rated for +/- 10% I believe...but most people seem to talk about 440-460VDC for a JTM45.
