Transformer Help
Posted: Wed Sep 23, 2009 5:35 pm
Hola. I'm new to this and as such upon flicking the switches to ON after completing my first 2204 clone build, I got a little bit of smoke and noticed the ground wires from my power transformer started to sag. They were humming and heating up quick fast. I ended up having to wrap them in some electrical tape because they actually managed to melt through in a couple spots. The layout I am following is this one...
http://www.joepopp.net/jcmtwins/jcmtwins003big.jpg" onclick="window.open(this.href);return false;
So the wires that are going nuclear on me are #7 and #10 on the PT. I tried disconnecting 8/6 from the turret board as well as 11/9 and tried powering things and then taking a reading with my voltmeter. The following is what I got...
http://frankblo.ws/DSCF4015.AVI" onclick="window.open(this.href);return false;
Similar results happened for the other set that didn't get tested in that video. The transformers I am using were bought from Triode. This is a 50W PT. Does anyone have any insight as to what I could have possibly done wrong? The only difference from the schematic I am using and the power transformer I have is that 8/6 would be 345V instead of 323, as that part of the transformer is rated @ 690V. 11/9 are fine as those on the transformer are rated 6.3V like the diagram.
At the suggestion of a more electronically inclined amigo, I went ahead and checked all of the resistors on the turret board. All of them read their normal readings except for the one identified in the following modified diagram...
http://frankblo.ws/low.jpg" onclick="window.open(this.href);return false;
When I took it off the turret board it read as 100K no sweat, but when installed on the turret board it reads ~4.5K. This drew my eye to the 4.7K resistor between the bus bar and ground on the presence pot, but I don't see how this could be related. Then again, like I said, I am new at this.
Any and all comments would be greatly appreciated. I really wanna fire this thing up!
