O50JM-MM WIRING
Posted: Sat Feb 13, 2010 9:53 pm
by Ivabiggun
Hi, does anyone know if the wiring for the O50JM-MM is the same as for the O50M? MM didn't send the diagram with the tranny. I have the O50JM diagram.
Thanks,
Ivabigggun
Re: O50JM-MM WIRING
Posted: Sun Feb 14, 2010 11:15 am
by arledgsc
Did you check the MetroAmp Wiki pages? Scott
http://metroamp.com/wiki/images/5/5f/To ... _O50JM.pdf
Re: O50JM-MM WIRING
Posted: Sun Feb 14, 2010 6:53 pm
by Ivabiggun
Yes I did check that, thank you. I just want to make sure the "MM" color code is the same. I installed a self-leads model once and didn't find out it was different until I had wired it in.
Just an FYI, I was reading a post about the differences between the standard and self-leads wiring. The posters stated that there was no tonal difference between the two models. When I ordered that one I talked to Sergio, and he told me the self-leads model had a greater mid-range emphasis.
Ivabiggun
Re: O50JM-MM WIRING
Posted: Mon Feb 22, 2010 6:38 pm
by Voodoo Amps
Ivabiggun wrote:Yes I did check that, thank you. I just want to make sure the "MM" color code is the same. I installed a self-leads model once and didn't find out it was different until I had wired it in.
Ivabiggun
This is true as wire does make a difference in the sound (IE: gauge and quality). Try one with Mercury's leads and then try one with Telfon wire. One is not better than another but rather different. Give it a go and see where it takes you and I'm sure you will have a lot of fun.
Have a great day
Trace
Re: O50JM-MM WIRING
Posted: Sun Feb 28, 2010 2:49 pm
by flemingmras
Have a great day
Trace
So all else being equal, are we also to believe also that you'll hear a night and day tone difference between PCB and P2P construction as well? :roll:
Ivabiggun wrote:When I ordered that one I talked to Sergio, and he told me the self-leads model had a greater mid-range emphasis.
That's not to say that it's due to the fact that it's self leads. This just states that the self leads model has a greater mid-range emphasis...more than likely a different wind, different inductance, etc etc...some other measurable quality affecting that and not the fact that it's self leads.
