How do I wire this Magnetic Comp bias tap?
All about iron and copper.
guilds100
Post by guilds100 » Sat Mar 20, 2010 10:22 am
I'm getting ready to use this transformer in a build but I have a question about the bias tap. I'm used to transformers where the bias tap comes from the high voltage winding and comes out as 1 wire with the windings ground coming from the center tap. This transformer has its own bias winding with neither end grounded by default. Do I ground the white wire and use the green for the bias voltage?
http://www.classictone.net/40-18024.pdf" onclick="window.open(this.href);return false;
Finished amps --> Metro JTM45, Champ, Deluxe, Bandmaster, 1974x
Still Debugging --> Metro 50, Trainwreck Express
Re: How do I wire this Magnetic Comp bias tap?
Post by Flames1950 » Sat Mar 20, 2010 11:38 am
Doesn't matter which one you ground. Ground one of them and send the other to your first bias resistor on the turret board, and you'll be set.
