Need to find out how to properly wire this type of selector.. It has a 120v 220v and 240v
Many thx for the help!
Voltage Selector wiring
- 5150loveeddie
- flemingmras
Re: Voltage Selector wiring
One of those bottom 4 terminals is your "common" terminal. Whichever one it is, it will be the one that has continuity with the other 3 terminals in all 3 positions. That wire goes to the mains switch.5150loveeddie wrote:Need to find out how to properly wire this type of selector.. It has a 120v 220v and 240v
The remaining 3 go to your 120, 220 and 240 taps. Use your meter to find out which terminal has continuity with the "common" terminal to know which on the switch is the 120, 220, and 240, then match up the colors of your PT with those terminals.
- 5150loveeddie
Thx Jon.......you rock bro..... My msn is down so as soon eit gets back I'll pop up!!
- 5150loveeddie
here is what I got, the 120v wasn't on the bottom but on a top terminal....
