How do I...?
Posted: Tue Apr 20, 2010 8:25 pm
Tell what impedance load an amp head needs to have, when it isn't marked?
For Class A Single Ended-Mars Hall wrote:Tell what impedance load an amp head needs to have, when it isn't marked?
LOL! I think the OP was asking how to figure out what load should be connected, if it is not silkscreened on the chassis of an existing amp. You gave him an answer, but in a round about way. The OP would need to disconnect the OT and figure out reflected impedance on the primary, by means of the turns ratio. with a small AC input signal on the seconday, a 1Vpk-pk signal @ 800hz, should be fine, you should measuer a much larger one on the primary. He would then use your method above to find the most Ideal load for the valves, and voltage used in the amp.flemingmras wrote:For Class A Single Ended-Mars Hall wrote:Tell what impedance load an amp head needs to have, when it isn't marked?
B+^2 / Max Plate Dissipation Rating = Zplate
For Class AB Push Pull -
B+^2 / (Max Plate Dissipation Rating x Number of Tubes) = Zplate-plate
"^2" means "squared", or multiplied by itself.
So if you have a Class AB Push Pull amp with 2 x EL34s, max dissipation rating for an EL34 is 25 watts. Let's say you're running a B+ of 450V -
450V^2 / (25 x 2) = 4,050 ohms...4K Zp-p would be close enough.
If it were a 100 watt at the same voltage -
450V^2/ (25 x 4) = 2,025...2K would be close enough, which is 1/2 the 50 watt required Zp-p, which allows the OT primary to draw double the current at the same voltage, which means double the power and the reason why two more tubes are needed (creates a 2nd path for that extra current to flow since one tube can only handle so much).
Of course, the power transformer would have to be able to source double the current, but you get the idea.
Oops...lol.joey wrote:LOL! I think the OP was asking how to figure out what load should be connected, if it is not silkscreened on the chassis of an existing amp. You gave him an answer, but in a round about way. The OP would need to disconnect the OT and figure out reflected impedance on the primary, by means of the turns ratio. with a small AC input signal on the seconday, a 1Vpk-pk signal @ 800hz, should be fine, you should measuer a much larger one on the primary. He would then use your method above to find the most Ideal load for the valves, and voltage used in the amp.flemingmras wrote:For Class A Single Ended-Mars Hall wrote:Tell what impedance load an amp head needs to have, when it isn't marked?
In either case I don't think he liked the answers too much (mine just doubled the work load), as it is not as simple as just setting the meter to the ohms setting. and putting the probes between two pointsflemingmras wrote:
What's funny is that I searched everywhere for those damn equations...didn't find them, and ended up having to figure them out for myself via drawing up load lines and all that engineering shit you've gotten me into.
Not everything on an amp can be done "paint by numbers" style.joey wrote:In either case I don't think he liked the answers too much (mine just doubled the work load), as it is not as simple as just setting the meter to the ohms setting. and putting the probes between two pointsflemingmras wrote:
Disconnect the OT wires from the amp. Plug the primary of the OT into a wall socket (i.e. the wires that came off of pin 3 of the output tubes) and measure the voltage at the secondary.Mars Hall wrote:Thanks guys for the responses. I'll be figuring it out hopefully this weekend. What can I use as a signal generator?
Mars Hall wrote:Ok know it's either an 8 or 16 ohm, Using Vac setting on my meter, I got 3.6 volts on the secondary. 120v / 3.6 = 33.33 turns ratio. 33.33 squared = 1110.89 x 8 = 8887.12 ohms or 8.8k. With a 16 ohm load 1110.89 x 16 = 17774.24 or 17.7k. Which is more ideal for 6V6 power tubes?
With two 16 ohm speakers, the only usable impedance you can wire them to would be 8 ohms by paralleling them. If you series wired them, it would be a 32 ohm load.Mars Hall wrote:I was told it was patterned after a Deluxe. BF or tweed, I'm not certain. The original speakers were 2 16ohm Celestians, so I figured they could only be wired to 8 or 16 ohms. The owner removed the speakers and doesn't remember how they were wired. That is why I took it upon myself to help him. As I have guessed everything is pointing to 8 ohms. I can check the plate voltage if you would like. The PT is very small.
The plate voltage is 430v does that sound about right for a Deluxe type circuit?flemingmras wrote:With two 16 ohm speakers, the only usable impedance you can wire them to would be 8 ohms by paralleling them. If you series wired them, it would be a 32 ohm load.
Knowing this bit of info I'm thinking it's safe to say that the OT you have is set up for an 8 ohm load with 6V6s.
Yep that sounds about right. With an 8.8K load at that voltage that should get you roughly around 30 watts.Mars Hall wrote:The plate voltage is 430v does that sound about right for a Deluxe type circuit?flemingmras wrote:With two 16 ohm speakers, the only usable impedance you can wire them to would be 8 ohms by paralleling them. If you series wired them, it would be a 32 ohm load.
Thanks for all your help.flemingmras wrote:Yep that sounds about right. With an 8.8K load at that voltage that should get you roughly around 30 watts.
