I bought a MM PT with a Bias wire. I don't need this wire.
Simple, Should I Ground the Bias wire or just put a heat shrink and not use it.
Thanks.
Bias Wire not needed...Ground it or put a heat shrink ?
- flemingmras
Re: Bias Wire not needed...Ground it or put a heat shrink ?
If you're sure that it's a bias wire, insulate it...DO NOT GROUND IT!David_Well wrote:I bought a MM PT with a Bias wire. I don't need this wire.
Thanks.
Which MM PT is it?
The MM Pt is the FPD-20M
I gonna shrink it
I don't use it cause i built a Class A Amp and I order a Single ending MM OT witch is SE-5K-MM
I gonna shrink it
