who makes a Black Flag / JTM50 OT ??
- antosimoni
Im searching for the greatest replica of the Black Flag OT (but Im thinking on PT also) Ive found that Black Flag irons could be more than one :
OT : 784-128 vs 784-139
PT : 1202-118 vs 1202-133
which one is the right one (Im thinking that both first options are best but need experts chimin' in) and which is the best replica out there?? do I will incur in voltage issues ??
thanks for any help
thanks for any help
in loudspeakers we trust
Re: who makes a Black Flag / JTM50 OT ??
Brian Wallace does the -128, -139 and -118.
http://marstran.com/JTM50-JMP50%20TRANSFORMERS.html
I do not know of a -133 clone. They are higher voltage.
My original JTM50 with -118 PT and -128 OT puts 410 volts on output plates with a NOS Mullard GZ34 but 360 with an old Russian Sovtek!
To use a really corny and much over exercised phrase it 'sounds killer!'
- Brian Wallace
- Supporting Advertiser
The 128's are in stock now.
The 133 is basically a JTM45 1202-55 PT with higher current capability.
- antosimoni
thanks,
before I order something can you please tell the impedance difference between 128 vs 139 OTs ??
Both are 3.5k.
I believe the -128 has a bit more low end response - Brian can tell you
ps Brian if you are reading this - are you stil collecting pictorial stuff of JTM/JMP50s? Your pictorial page is not on the home page drop down - still a great resource
- antosimoni
great, thanks, is your JTM50 with 470k or 270k res on mixer ??
- Brian Wallace
Neil,
Yes, I am still accepting Marshall pictures. The page is still there but the link is missing right now. http://marstran.com/Marshall%20Pictorial%20Page.htm
antosimoni,
The JTM50 will have the 470k mix resistors.
Brian
antosimoni,
Brian
- antosimoni
great inf, thank, just one final request : when Marshall changed the Presence pot from 5K to 25K ?? I was thinking this change occured from the JTM to the JMP but I dont know if the JTM50 already have a 25K pot, can you please clarify ??
My original has 270k mixers with 556pF bypass cap, single 10k dropper on board and single 32uF filter cap on the board. I replaced the dead 32uF mains can with reformed RS 16/32 = 48uF mains, stock PI and screens. So almost a JTM45 in those respects. It has -128 OT and -118 PT. It has white rear panel with single rear fuse holder.antosimoni wrote:great, thanks, is your JTM50 with 470k or 270k res on mixer ??
For this reason I suspect Brian might want pics for his site, there are other similar amps in his historical database but not the pictorial one.
http://vintageamps.com/plexiboard/viewt ... 1&t=101591
I have a half built clone in one of Dom's block end chassis with Brian's transformers on which I will use 470k mixers with 556pF cap and x2 10k droppers and dual 32uF preamp filter. The rest of the components will be identical I hope. This one will have gold rear panel and both fuses on the back.
It will be interesting to compare the two.............
- antosimoni
great amp (added my comment
) !! did it sports a 5K or 25K Presence pot ? its nt clear to me when MArshall started with 25K ones
PS : now I need also a replica of the 3H 352-114 choke...
5k pot. I think the 25k came in around '74 or so. The C1999 does the same job!antosimoni wrote:great amp (added my comment) !! did it sports a 5K or 25K Presence pot ? its nt clear to me when MArshall started with 25K ones
