Heyboer 1202-118 Schematic Question
All about iron and copper.
guitarcal
Post by guitarcal » Fri Mar 11, 2016 5:59 pm
Hi all,
This is my first post! The information on this forum is awesome!
I am installing the Heyboer 1202-118 PT in my 50 watt build.
The Metro Amp build schematic mentions a black, brown, orange, and yellow wire for power. Unfortunately, my transformer has no orange wire.
I have 1 solid black wire and the remaining 3 wires have a white stripe, a yellow stripe, and a brown stripe.
Can I assume the solid black wire is the common wire and the brown stripe wire is the 120 V AC supply? If this is the case I would cut and shrink tube the remaining wires.
axeman
Re: Heyboer 1202-118 Schematic Question
Post by axeman » Fri Mar 11, 2016 6:44 pm
Do you mean 1202-118?
guitarcal
Post by guitarcal » Fri Mar 11, 2016 7:02 pm
axeman wrote:Do you mean 1202-118?
Yes, the 1202-118. Thanks, I made the edit above.
axeman
Post by axeman » Fri Mar 11, 2016 7:07 pm
Where do you live?
guitarcal
Post by guitarcal » Fri Mar 11, 2016 7:29 pm
axeman wrote:Where do you live?
Oklahoma, interested in the 120 V AC supply.
axeman
Post by axeman » Fri Mar 11, 2016 7:44 pm
Yes the Brown Lead wire is for 120v. The Black is 100vac.
Does this help.
guitarcal
Post by guitarcal » Fri Mar 11, 2016 7:46 pm
axeman wrote:Yes the Brown Lead wire is for 120v. The Black is 100vac.
Does this help.
I believe so. So is the Black 100 vac the same as the Common Black George references in his 50 watt build guide?
axeman
Post by axeman » Fri Mar 11, 2016 7:56 pm
On what page? vac goes to the fuse if I remember correctly.
guitarcal
Post by guitarcal » Fri Mar 11, 2016 8:00 pm
axeman wrote:On what page? vac goes to the fuse if I remember correctly.
Bottom of page 11, it mentions the common black wire to the fuse.
Appreciate your quick responses!
axeman
Post by axeman » Fri Mar 11, 2016 8:03 pm
Ok common does mean "ground" but on your PT it goes to Main Fuse.
guitarcal
Post by guitarcal » Sat Mar 12, 2016 10:17 pm
axeman wrote:Ok common does mean "ground" but on your PT it goes to Main Fuse.
Alright, wired up everything and began checking voltages. For my heater voltage, I am receiving 1.3V AC on the tube socket terminals. The instructions say I should be around 3.15.
Is it possible the brown stripped wire is not rated for 120V on this power transformer?
axeman
Post by axeman » Sat Mar 12, 2016 10:24 pm
No the brown wire is for 120v. Maybe you did something wrong, post pictures. Do you have a Layout to follow?
guitarcal
Post by guitarcal » Sat Mar 12, 2016 10:34 pm
axeman wrote:No the brown wire is for 120v. Maybe you did something wrong, post pictures. Do you have a Layout to follow?
Probably true... Yes, I followed the 50 watt build.
Here are a few pics of the power sections:
http://i1131.photobucket.com/albums/m55 ... G_1362.jpg
http://i1131.photobucket.com/albums/m55 ... G_1360.jpg
http://i1131.photobucket.com/albums/m55 ... G_1358.jpg
axeman
Post by axeman » Sat Mar 12, 2016 10:40 pm
Check the ground for the heaters, make sure the work is solid, then make sure that the color you chose that goes to pin 7 goes to every pin 7 of the power tube sockets and every pin 2 wire goes to every pin 2 of the power tubes, and the same with the pre amp tube sockets but obviously it's pin 4 and 5 together and then pin 9. Yah that reading is low
Send me your email so I can send some Layouts to follow.
guitarcal
Post by guitarcal » Mon Mar 14, 2016 10:30 am
Finally figured this one out. Heyboer used their internal color codes for this transformer build.
Black - 0, black/white - 120, black/yellow - 220, black/red - 240. The black/red looked brown to me, which is why i assumed this was their 120.
I connected the black/white and get 2.9 - 3V at the heaters. Still a bit low, but from what I read its fine. I tested everything else and fired up the amp, everything sounds great.
Thanks axeman for sending the schematics and the help.
