Wiring diagram needed
Anyone have the wiring diagram for the Metro Dagnall clone OT C1998? Build journal I’m referencing only uses the connections by color… not the value of the wire. The link is dead that’s in this thread. Any help would be appreciated. Thanks.
Re: Wiring diagram needed
Primary Leads:
Brown: is for Valve #6 & #7 (Pin #3 on the octal sockets).
White: Center-tap.
Red: is for V4 & V5 (Pin #3 on the octal sockets.
Secondary Leads (self-lead; cloth covered):
Green: 16-ohm.
Yellow: 8-ohm.
Black: 4-ohm.
Brown: Common (negative; speaker jack).
Note: To ensure proper phasing of the output transformer, the 82K Phase Inverter plate resistor (pin #1 on pre-amp valve #3) feeds V4 & V5. The 100K Phase Inverter plate resistor (pin #6 on pre-amp valve #3) feeds V6 & V7.
White: Center-tap.
Green: 16-ohm.
Yellow: 8-ohm.
Black: 4-ohm.
Hi, if you haven't found the answer yet, I think you can go to our website https://www.heisener.com/ to make a consultation, there are professional customer service to help you solve any problem you have.
