hey guys, i was wondering if it would be ok to restring my nylon string acoustic with steel strings?
I would be using 9-42 guage, the reason i ask is, although theres no truss rod, i cant see 9s givin THAT much more tension than what its holding now.
Also, with guitars like Martin 0-18's which are steel strung, with no truss rod, i was wondering if it would be possible.
Thought id check with you guys first
Tom
Restringing a nylon?
- TomGibbs
- Yngve
Not such a good idea, especially when the tension will be much more plus the steel string will cut into the bridge. I wouldn't do it.
You should always B sharp, never B flat, and just B natural.
Success is the ability to go from one failure to another with no loss of enthusiasm - Mykola Skarpheddinson
- yngwie308
Without adequate top bracing and support even with silk and steel strings, you'll be popping the top and bridge off your guitar...
- TomGibbs
- 45auto
they dont usually have truss rods do they? who's rig is that Y308? looks good!
- yngwie308
Tom Keifer of Cinderella, yes he has the bases covered with that setup. Tom has always had cool guitars and amps.
Nylon stung guitars never have had truss rods.
- Yngve
My Classical guitar hasa truss rod. La Patrie from Qubec Canada, l know its weird but it has.
This is my pride and joy my top guitar. David Argent what a gentle giant, even came to my home from interstate to show me his guitar, and l ended up buying the Spruce model.
- argent-new.jpg (314.93 KiB) Viewed 631 times
- argent-new.jpg (382.72 KiB) Viewed 452 times
- yngwie308
Not cheap my friend!
This is what I have my eye on next.............
SWR California Blonde II amp, Roland GA-20 Synth, Godin Multiac SA guitar, 25.5" scale length, 16" radius, ebony fretboard, on board synth controls and equaliser.
