have anyone tried to rise the polescrews?
this gives a slight single coil effect which is nice on the neck pup bass strings IMO
Anyone else find a LP neck pickup hard to dial in?
- gutpile
- marT
- fillmore nyc
Well, arent JTM45's known to fart out on low notes when they're pushed hard? My understanding is that the neck pup should be relatively low in output, and the amps trannies have almost everything to do with the overload that occurs when pushed with "bass-y" notes. Any true JTM45 I've ever played thru HAD to have the bass turned down to 3 or 4 if the amp was played loud, ESPECIALLY on the neck pup, or it would fart out.
On the other hand, my Soldano, which has huge MM trannies, can have the bass set on 10, AND the depth set on 10 at all times, regardless of volume, and its always tight, even though the neck pup on my LP reads hot (8.09k) on a DVM. I think thats one of the reasons players upgrade to MM trannies. Correct me if Im wrong on this, but its the way it was explained to me.
