jimmyride wrote:Awesome man !!
Thanks. I'm considered a hack until I make 5 of them by the other LP forum builders
. I'm just hiding this on the Metro amp forum so I dont get critics.
My amps get critics enough here.
I'm spending a lot of time making jigs on this one and rethinking easier ways to do things. I'm also working on a simple jig to do the truss channel without a table saw.
I was thinking about what you asked me regarding the spindle sander. Really... if you have top and a bottom router bearing bits, you could get those perfect 90 degree angles you need on the initial mahogany part. I'll give it a try on some scrap. I see everyone cuts out the mahogany and then sands down to the line. Why not just rough cut to about 1/8" of the line , then route it from the template with a top bearing bit, then remove the template, flip the piece over and use a bottom bearing bit up against the part you just routed? In fact it would be perfect to the template. Not sure why nobody does that?
I'll ask Tom B. perhaps regarding such. You wouldn't need the spindle sander, just a sanding block at that point.Seems legit to me.......
Getting the perfect 90 on that mahog is what sets up everything else.
