Know anyone that can install a brass nut properly?
Building a guitar and will need someone to install the brass nut properly and also cut the grooves 'wider' to allow the strings to move more.
Know anyone who is good at doing this?
If there's no quiet, there can be no loud.
- 908ssp
I use Superglue I have heard others use white glue. I don't like white glue because it is thick and you need to clamp the nut to get nut to neck contact you don't need to do that with superglue it only takes a couple drops. Make sure the fit is perfect against the head stock and fret board on nuts that go at the end of the board like Gibsons. On Strat style nuts you don't even need glue if the fit is tight enough. If the slots are started it is easy to widen the slots with the proper nut files. If the slots aren't started you need a special ruler from Stew Mac for sting spacing. Strings are not evenly spaced center to center they are spaced edge to edge in other words the gaps between the strings are even. Any decent tech should be able to help you.
- Bluesman
I made one out of Navel Brass once before. It was the first time I did one and it came out perfect. I wanted to try to eliminate a dead sounding cheap double neck SG I had at the time hoping that swaping the plastic nut for a metal one would help with the sustain properties. It didn't, but that thing sure had a bright finish! But like 908ssp says, Stew Mac will have everything you need to know on how to do it. For that matter, if your building a guitar, the Nut should not be more challenging than what you've done up to that point. Go for it!
They hate you if you're clever, and they despise a fool...JWL
Re: Know anyone that can install a brass nut properly?
I have a shop and do this type work, I am about 90 miles north of Dallas Tx, its not hard to install yourself? but if you want it done contact me,be happy to do it. Steveblfrd wrote:Building a guitar and will need someone to install the brass nut properly and also cut the grooves 'wider' to allow the strings to move more.
- Guitar Adjuster
Bluze,bluze81 wrote:I have a shop and do this type work, I am about 90 miles north of Dallas Tx, its not hard to install yourself? but if you want it done contact me,be happy to do it. Steveblfrd wrote:Building a guitar and will need someone to install the brass nut properly and also cut the grooves 'wider' to allow the strings to move more.
You located in Witchita Falls? Or along the OK boarder?
- zaphod777
- Bluesman
