DO U HAVE TO GET A F-SPACE NECK HUMBUCKER FOR FLOYD BRIDGES?
Posted: Thu Dec 06, 2007 10:58 am
by MARCO
IS IT A MUST GET A F-SPACE FOR THE NECK P/U ON A 1-5/8" NECK?
Posted: Thu Dec 06, 2007 11:00 am
by St August
if you want your poles on your pup to line up... Yup. neck width doesnt play a part in weather is f-spaced or not..
Posted: Thu Dec 06, 2007 11:03 am
by Scumback Speakers
No. The field produced by a pickup is plenty wide enough that an F Spaced pickup isn't necessary. It's purely cosmetic...and makes the pickup winders more $$$.
Posted: Thu Dec 06, 2007 12:40 pm
by rockstah
Southbay Ampworks wrote:No. The field produced by a pickup is plenty wide enough that an F Spaced pickup isn't necessary. It's purely cosmetic...and makes the pickup winders more $$$.
+1
Posted: Thu Dec 06, 2007 12:49 pm
by MARCO
thanks guys. i am basically replacing the wolfgang pickups in my wolf and putting in dimarzio virtual paf hot in the bridge and virtual paf neck in the neck. not a fan of high output p/u'ps anymore. you lose articulation, detail and charcter with them. 9-10k in bridge is enough.
Posted: Thu Dec 06, 2007 12:52 pm
by rockstah
i hear ya. my darkburst is something like 8.2k
Posted: Thu Dec 06, 2007 6:51 pm
by Winder
I hate winding F-Space. Charging more though. There's an idea!
I had a guy once send an e-mail tirade over the fact that the pickups I just built for him weren't the correct spacing (a fact we'd neglected to hammer out ahead of time). He hadn't even tried them out yet. I just asked "well, how do they sound"? He ordered 4 more.
Some folks claim dead spots when bending on one end or the other but for the most part it's not a big issue.
Posted: Thu Dec 06, 2007 7:47 pm
by JD
I would only recommend the wider f-spacing in the bridge position and standard spacing in the neck. Gibson sells the Les Paul Classics (496R/500T) this way.
Posted: Sat Dec 08, 2007 12:27 pm
by fillmore nyc
You dont need an "F" spaced pickup in the neck position at all. Think about it.. if the spacing was significantly wider than a stock HB's spacing, the strings would be too close to the edges of the fretboard. It only an issue as you get close to the bridge (the bridge pickup), and even then, really only for the "E" strings. The "A/B" strings, and especially the "D/G" strings are pretty much in line, no matter which pickup spacing you use. There is even a line of thought that says if the "E" polepieces are slightly inboard (narrower) than the string spacing at the bridge, you actually GAIN signal when string bending, cause it pushes the strings closer to the poles at that point.
Honestly, its all bullshit. Get an "F" spaced pickup for the bridge if you feel better about it, and just a standard spaced pickup for the neck.
BTW, look at EVH's guitar... the poles are not lined up with the strings at all, especially the "E" strings. Pickup builders have a field day concerning players with this kind of thing. Its got some validities, but its not a critical issue.
Posted: Sat Dec 08, 2007 12:55 pm
by rockstah
+1 no f space needed on a Les Paul guitar. f space is for the bridge of a strat style guitar. and again as mentioned its not necessary.
Posted: Fri Dec 14, 2007 5:00 pm
by Herec
But is it ok to put an F-spaced pickup in a standard gibson guitar with a standard gibson spaced bridge?
Posted: Fri Dec 14, 2007 5:36 pm
by 45auto
it won't explode or anything, but why would anybody want to?
Posted: Fri Dec 14, 2007 6:24 pm
by Herec
they like the sound of single coils but like the shape/neck of a gibson
Posted: Sat Dec 15, 2007 11:26 am
by fillmore nyc
Posted: Sat Dec 15, 2007 2:35 pm
by Herec
Putting a Fender single coil pickup in a gibson, is what I meant. I thought Fender spacing is what everyone meant by F spacing.
My bad.
