You do could that with a boring bar on a milling machine.wide slide wrote:using the application posted,
if one used an expanding type insert similiar to an expanding anchor, where the end flares out would work better.
If someone could invent a drill bit that would be able to expand the hole in the maple at a certian depth, this would lend itself well with this application but I don't think there is such a tool.
Well, I COULD grab my wifes cell phone and call... ummm, lessee... myself...yngwie308 wrote:I would ask Fender or a competent Luthier about it.
Actually, that IS possible using a high speed cutter dremel tool bit like this:wide slide wrote:using the application posted,
Not on my street bikes, but years ago I stripped out the sparkplug on a dirtbike I had, and used a helicoil to repair it, so I know what you mean.NY Chief wrote:fill, these things take a lot to pull or torque out when installed correctly. They're like helicoils or keenserts I'm sure you've used them at some time working on your bikes?
Ummm, no Gabriella works at Lace, which is a "gentlemans"wide slide wrote:Good Fill!![]()
but whats funny like you mention, take a few words like Strip and mix some of the words... like in the sentence above, and it can take on a XXX meaning.![]()
I take it Gabe is Mrs. Fill?
