Before I throw this axe down the street JESUS lol the ground I'm having a huge issue single pup easy right?? Ash Strat body, can we use amp wire in this to ground shielded wire. I wired up and still have huge ass ground problem I mean its one pickup for gods sake HELPPPPPP
I have duncan JB model grounded to back of 500 k pot there is a ground back on the stock trem grounded to little screw then to pot damn still huge ground problem not the pup I just switched her out any suggestion please or help will be appreciated!
Thank you
Wiring help please
Wiring help please
Metro 2204
Metro JTM 45/50
Next Super lead??
Metro JTM 45/50
Next Super lead??
- 908ssp
Well she wont ground?? I tried wiring all the ground to the back of the pot nope huge hum and ground issue, I tried to ground to the little screw inside the body cavity in the pickups no?? I'm thinking this body will not ground, I put a jb in here new and put her in working axe all fine I put in the ash body ground issues?? I wrote the guy whom sold and he was like i will take it back Im thinking thats why he sold the dern thing??? Its a MIM ash body blond. I do not understand I tried every single opt of wiring and still ground loud hum.908ssp wrote:What's the problem?
its only one pickup lol I have done this a million times lol this one wont work, Oh I did change out the mag in the JB to a alnico II and it worked in my other guitar thought maybe that might be it nope?? weird
I got wire on the way specific wire for wiring jacks and guitars, could it be bad jack? I just got from stewmac??
Metro 2204
Metro JTM 45/50
Next Super lead??
Metro JTM 45/50
Next Super lead??
- fillmore nyc
Have you checked all your grounded items with a continuity tester? The following should give you a continuity signal: The jack sleeve, the metal pickup mounting frame, the bridge, strings, pot cans and shafts... even the tuners if you have strings on the guitar. You should have a continuity signal from the jack sleeve to all of these points. Does the pickup have a metal cover? It should have continuity to ground as well, obviously not to the hot lug of the jack, otherwise the pickup may be wired backwards, if its a co-ax (Gibson style) wire. THAT would cause a severe hum situation.
fillmore nyc wrote:Have you checked all your grounded items with a continuity tester? The following should give you a continuity signal: The jack sleeve, the metal pickup mounting frame, the bridge, strings, pot cans and shafts... even the tuners if you have strings on the guitar. You should have a continuity signal from the jack sleeve to all of these points. Does the pickup have a metal cover? It should have continuity to ground as well, obviously not to the hot lug of the jack, otherwise the pickup may be wired backwards, if its a co-ax (Gibson style) wire. THAT would cause a severe hum situation.
Thank you! I will check this out, i know this is insane?? Same setup just different body thats it? I took all hardware from one single pickup alder body and put it on this ash MIM strat body and I'm talking serious ugly ness from it. No cover on the pup JB model the pick G single hummer and shielded, def strange and mind boggeling never had this issue its a solder plug and play and away i go not this one lol
Thanks will check back when i try this out!
ILMM
Metro 2204
Metro JTM 45/50
Next Super lead??
Metro JTM 45/50
Next Super lead??
got it
got it thanks would help if I grounded all jesus sometimes I guess you need to step away from it and think she works great
I forgot to run ground from lug to middle lug on pot ;-(
thanks all!!
thanks all!!
Metro 2204
Metro JTM 45/50
Next Super lead??
Metro JTM 45/50
Next Super lead??
