Wiring troubleshooting
F#m7
Post by F#m7 » Tue Aug 12, 2008 10:37 am
I recently ordered a set of pots and caps from Dr. Vintage. The neck controls work fine, but the bridge controls do not. I have checked all wiring from the toggle to the jack. What would I need to do to check on those pots to know if one is bad? I can hear a very faint sound on the bridge PU if I crank the volume on my amp, like someone is playing guitar a block away! But obviously that's not right. When in the middle position with both volumes full up, you get nothing, turn the bridge volume down a hair, bam, volume comes up and you can hear it fine. I measured resistance across both pots and the neck shows .514 and the bridge .509. Please advise. :(
acdc51502112
Post by acdc51502112 » Tue Aug 12, 2008 1:49 pm
to test if they are bad just wire the bridge to by-pass each pot. Could also be a dead pup? Double check the wiring with different sources.
F#m7
Post by F#m7 » Tue Aug 12, 2008 5:27 pm
Thanks for the help. Rick is the man! He really went above and beyond to help me troubleshoot, and a new pot is on the way. :)
Guitar-Sam
Location: Various venues earning money to pay off gear LOL
Post by Guitar-Sam » Tue Aug 12, 2008 6:15 pm
Alligator clip the pickups + strait to the switch that'll tell ya if the pup and switdch are good.
74' Stratocaster
Several Frankenstrats
Orange Tiny Terror & PPC 1x12 cab
Marshall 2210
69' Marshall 4x12 "B" cab
Dean Markley CD-60
