Stop tail piece question
Mars Hall
Post by Mars Hall » Wed Nov 26, 2008 2:20 am
How do you LP guys have your stop tail piece set? I see a lot that are screwed all the way down. Is there a right or a wrong way, or is it to taste?
I noticed if mine are all the way down, the string rides the saddle and rests on the back edge of the bridge behind the saddle as well. So, I've been backing out the studs enough to clear the bridge body and only rest on the saddles. :?:
Frank_Heritage
Re: Stop tail piece question
Post by Frank_Heritage » Wed Nov 26, 2008 5:13 am
Mars Hall wrote:How do you LP guys have your stop tail piece set? I see a lot that are screwed all the way down. Is there a right or a wrong way, or is it to taste?
Mostly players will achieve the best possible transmission of vibes between the hardware and the body. Depending on what kind of bridge/stp is used, you have to screw it down all the way to provide strong connection. But there are several solutions to get that connection pretty well without screw it down that far.
Most players prefer a more flat angle of string guidance between the bridge and the stp. It seems to make string bending a little bit easier and feels somelike more smooth while playing.
I prefer top wrapping: You thread the strings from the pickup side through your stp and than wrap them around back. So you can screw your stp all the way down for best connection but still get a lat angle. And the best of it: It looks very cool.
I suggest you to look over here: http://www.lespaulforum.com
At this forum you will meet all real LP lovers and freaks. That topic leads you to reading for more days than your chrismas holidays can ever provide. :wink:
908ssp
Post by 908ssp » Wed Nov 26, 2008 12:39 pm
I'd say most set the stop tail so the strings just clear the bridge. Some do the top wrap I have to try that one day.
I mod the hold down bolt. I remove the lower flange altogether and make short tubes of aluminum like really thick flat washers and then bolt the stop tail down solid against the washer and the body. The strings clear the bridge. Someone sells a kit for that too.
Scumback Speakers
Supporting Advertiser
Post by Scumback Speakers » Wed Nov 26, 2008 12:49 pm
I've gone another way...I buy the RS Guitarworks special steel tailpiece bolts that are a hair oversize. They snug up real well to the screw anchor studs, and then I top wrap it to boot!
Frank_Heritage
Post by Frank_Heritage » Wed Nov 26, 2008 5:05 pm
908ssp wrote:I mod the hold down bolt. I remove the lower flange altogether and make short tubes of aluminum like really thick flat washers and then bolt the stop tail down solid against the washer and the body. The strings clear the bridge. Someone sells a kit for that too.
This is offered by Faber (and btw the kit I have installed and I like it very much):
http://www.cvguitars.com/parts/FaberRPL-110107.html
But I would also take a look at ProTone: http://www.tonepros.com/
908ssp
Post by 908ssp » Thu Nov 27, 2008 11:54 am
Yes that is it. I think it is funny that they patented that. I did that for the first time 20 years ago.
I will try the top wrap one day. I am thinking of trying some different pickups in my LP and if that happens I'll top wrap.
