Well, when I finally got it over here I took it out of the case and I relized that the neck didn't quite line up right and seemed to be canted slightly off to the right...leaning slightly towards the lower horn. I took a close look at the neck pocket and realized that the bottom of the neck was more curved than the pocket of the body, so it wouldn't seat all of the way in.
I guess my question is, with the neck already being drilled for the neck screws, if I get a new body that is already pre-drilled as well, am I most likey going to run into problems with them lining up as long as the neck pocket has the same dimensions as the heel of the neck? The neck was obviously something the previous owner bought and tried to stick on the body and realized it didn't work right...and pawned it off on some sucker.
