Oil finishes: Tung, Teak, Danish, Tru Oil, Beeswax?
Posted: Sun Feb 22, 2009 1:56 pm
Just got my new warmoth neck in. I was going to use a tru oil finish b/c it sems to offer a little better protection for the wood then tung oil , but I've heard that it's not quite as smooth feeling as tung. From what I understand, tru oil is mostly a blend of linseed oil and mineral spirits, and I found something that seemed comparable at Home Depot, which is Watco Teak Oil.
I bought a can of teak oil, which also seems to be a mixture of linseed oil and mineral spirits, a can of tung oil...nothing else in it, just tung...and a bottle of Howard's "Feed-N-Wax"...which I think is a mix of orange oil, mineral spirits, carnuba and beeswax.
Anyways, here's my plan; I wanted to bounce if off some of you guys that have already done this to see if I'm tracking here.
1) Rub the neck down with 0000 steel wool
2) Apply 1 coat of Teak oil...wait 24 hrs to dry, wipe off excess and buff the neck, lightly rub w/ steel wool, repeat 3x
3) Apply 1 coat of tung Oil...wait 24 hrs to dry, rub down the neck, steel wool, repeat 3x
4) Give the neck a week to cure, buff the neck and apply the wax to help seal the neck, then buff it again.
Is this alright? I'm definitely open to suggestions.
