500k potentiometer question
meltingfaces
Post by meltingfaces » Fri Apr 17, 2009 8:38 am
I'm currently in the process of gutting out an epiphone prophecy em-2 for all new electronics and I stumbled upon an issue I never considered before. The mounting holes for the 2 pots are 5/16" which is just too small to fit the 3/8" pots I already bought. I've searched high and low and it seems the 5/16" pots are much less common - any reason for this?
paulster
Re: 500k potentiometer question
Post by paulster » Fri Apr 17, 2009 11:36 am
Epiphones use metric pots (and hardware) rather than imperial, so you just need to ream out the mounting holes slightly. I had to do this when I upgraded the wiring on a pal's Epi Les Paul and the new pots wouldn't drop straight in. It does, of course, mean that you have to replace the knobs with imperial ones too.
A tapered hand reamer is perfect for the job as a couple of turns is all it takes.
DanO
Post by DanO » Sat Apr 18, 2009 8:16 am
paulster wrote:Epiphones use metric pots (and hardware) rather than imperial, so you just need to ream out the mounting holes slightly. I had to do this when I upgraded the wiring on a pal's Epi Les Paul and the new pots wouldn't drop straight in. It does, of course, mean that you have to replace the knobs with imperial ones too.
Paulster's got it right---a hand reamer is definitely the way to do it; using a drill bit/drill is inviting chipping and splitting around the hole. Don't ask me how I know :(
Interestingly, the pot shafts are often (not always) the same size, so knobs will fit either/both.
908ssp
Post by 908ssp » Sat Apr 18, 2009 4:47 pm
Yup what they said. :lol: :wink: :mrgreen:
