Trems
Elbutcho
Trems
Post by Elbutcho » Tue Feb 28, 2012 9:53 am
I'm going to build a franky type strat....what kind of trem should I go with that will stay in tune with a lot of abuse...Floyd?
Ted B
Re: Trems
Post by Ted B » Tue Feb 28, 2012 10:16 am
If you're like me and want a non-Floyd, vintage style trem that sounds strong and works without a hitch:
Super Vee Bladerunner
https://super-vee.com/products.html
Elbutcho
Re: Trems
Post by Elbutcho » Tue Feb 28, 2012 11:22 am
Ted B wrote:If you're like me and want a non-Floyd, vintage style trem that sounds strong and works without a hitch:
Does this stay in tune like a floyd?
Ted B
Re: Trems
Post by Ted B » Tue Feb 28, 2012 11:23 am
It does, amazingly well.
See it demonstrated on Youtube.
Elbutcho
Re: Trems
Post by Elbutcho » Tue Feb 28, 2012 1:40 pm
Looks pretty cool as I do hate messing with Floyds but love that you can lay on them and they stay in tune.....are you using the bladerunner or the super and I'm guessing both require the mag lock.
Elbutcho
Re: Trems
Post by Elbutcho » Tue Mar 06, 2012 11:09 am
Did you purchase the Complete Super-Vee Kit $349.95 snf what mounting did you get 2 post or or 6 screws?
Ted B
Re: Trems
Post by Ted B » Tue Mar 06, 2012 12:10 pm
I bought the Super Vee Bladerunner, which is like a vintage strat bridge, although it works much better due to its innovative design, and doesn't go out of tune. It's a universal mount, which matches both 6-screw vintage (what I have) and modern two post mounts. It has quite a bit of mass, so it sounds much better than cheap, pot metal Asian made bridges.
It's only $149:
https://super-vee.com/order.php
Elbutcho
Re: Trems
Post by Elbutcho » Fri Mar 09, 2012 11:44 am
Ted B wrote:I bought the Super Vee Bladerunner, which is like a vintage strat bridge, although it works much better due to its innovative design, and doesn't go out of tune. It's a universal mount, which matches both 6-screw vintage (what I have) and modern two post mounts. It has quite a bit of mass, so it sounds much better than cheap, pot metal Asian made bridges.
It's only $149:
So the Bladerunner stays in tune even ehen doing VH bar dives?
yladrd61
Re: Trems
Post by yladrd61 » Fri Mar 09, 2012 11:50 pm
Theres a nice Floyd with Brass block on the Member Classified thread ;)
stef
Re: Trems
Post by stef » Sat Mar 10, 2012 12:08 pm
I use a fender 6 screw vintage trem, gig with it, record etc... The best setup guide is on fender.com and it works and sounds really good ...especially with the fender xl150
