Will a 50 watt plexi fit into a jtm45Bluesbreaker combo cab?
Thanks in advance.
- Mars Hall
Re: Will a 50 watt plexi fit into a jtm45Bluesbreaker combo cab?
If you are refering to a Marshall made reissue cab, no. The addition of tremelo on the bluesbreakers makes the opening on the cabinet, for the faceplate, wider. If you go with a another cabinet builder, they generally make them to fit the standard jtm45 faceplate layout.
Thanks for the info. I was looking at this one made by Weber. Looks like it might work with the chassis dimensions mentioned.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 602_263622" onclick="window.open(this.href);return false;
