looking to improve my 50 watt
Guys - I build a 50 watt metro amp kit last year to lead specs. I installed a lar-mar PPIMV. I have been using he amp with a variety of guitars - mostly humbucking pickups. Marshall 1960A classic cab with a combination of celestion 35 watters and weber stan spec speakers. I have come to the conclusion that the amp is harsh sounding and I am not happy with the lack of bass response.
If I crank the amp wide open and dime the PPIMV (essentially removing it), I can get a reasonable (but still slighty harsh) sound. Here are my settings: channels jumpered, vol I on 9-10, vol II on 6-7, treble on 8, mid and bass at 10, presence 0. The problem is, I cannot play at those volumes. I am starting to think attenuator possibly in conjunction with the PPIMV. I have tried the amp cleaner and lower volume with overdrive pedals and I just find myself saying why do I have a Marshall if I am going to do this. The tubes are the kit tubes, JJ - wonder if changing to NOS preamp tubes would help.
Any ideas or experiences?
Re: looking to improve my 50 watt
my 50w is neither harsh nor lacking in bass response. this sounds somewhat strange. however, I have to admit that I don't care for JJs (but it seems unlikely that they lead both to harshness and weak bass response)
I am using two G12M Celestion greenbacks and two weber "stan spec" speakers
http://forum.metroamp.com/viewtopic.php?t=9694" onclick="window.open(this.href);return false; in a 4 X 12 slant marshall cabinet.
If the amp has a bright cap, I'd try removing it and see how you like that. Also back off the bass knob to less than half, diming the bass knob only serves to muddy the waters in Marshall circuits I reckon, I don't go past 10 o'clock usually but anyway, try removing the bright cap, let us know what value it is, if it's a .0047uf or 5000p you could try 100p but see how you like it removed first. After that you could try swapping out the .002uf cap on V1b for a .022uf if it does indeed have the .0022.
Already changed out the bright cap to 100p - I could try lifting it and see what it does. What changes does swapping to a .022 on V1b give?Coot Boy wrote:If the amp has a bright cap, I'd try removing it and see how you like that. Also back off the bass knob to less than half, diming the bass knob only serves to muddy the waters in Marshall circuits I reckon, I don't go past 10 o'clock usually but anyway, try removing the bright cap, let us know what value it is, if it's a .0047uf or 5000p you could try 100p but see how you like it removed first. After that you could try swapping out the .002uf cap on V1b for a .022uf if it does indeed have the .0022.
It will take out some of the bite for lack of a better tone word, you could be hearing it as harshness.
Are you certain all of your speakers are in phase and correct polarity (all pushing forward)?
Part of the reason i run my 71 Marshall Smallbox 50 with a variac set at about 108 wall volts is it reduces volume a bit and is warmer and smoother when you rebias to 60-70%.
How hot is your bias/current draw on those EL34s?
- flemingmras
Going with a lower voltage transformer will do the same thing and be safer on your heaters. Variacs have no place on an amp except for slow powering up an amp on the bench.jcs wrote:Are you certain all of your speakers are in phase and correct polarity (all pushing forward)?
Thanks for your opinion but i have 20+ vintage amps so i dont have time to mess around with anything but a variac and have had ZERO problems in 15 years of using a variac set to 105-110.
90% of my stuff never leaves the house and heater issues have never been an issue as most of the time i run around 110 wall volts except for my 71 Marshall and my 1950s amps its a bit lower.
The heater problems are normally with much use at below 100 wall volts and usually wear on preamp tubes most of my amps dont see many hours as i am mainly a hobbyist.
I dont go down to 90 wall volts or whatever Eddie Van Halen did, 105 is the limit.
- flemingmras
Well vintage amps are one thing. Their turns ratios were made for a 110VAC wall voltage. However, a lot of guys will get the impression that it's OK to do this on amps with modern day transformers that have turns ratios designed for modern day wall voltage of 120VAC.jcs wrote:Thanks for your opinion but i have 20+ vintage amps so i dont have time to mess around with anything but a variac and have had ZERO problems in 15 years of using a variac set to 105-110.
Then there's the guitarists that are the "if there's a knob there, that means it should be turned otherwise why would their be a knob there" types. And you know where that leads.
Maybe I should change my statement to "Variacs have no place but on the bench unless you fully and truly know what you're doing" because technically, in electronics ANYTHING can be done, but there's certain people you wouldn't share that info with because there's just some things you shouldn't do unless you know full and well what you're doing. Not saying that YOU don't, but anyone can be reading our posts at anytime which is why I'm very careful with what I tell people in regards to things I do with my rig. Certain people will read it and interpret it as "Well if he's doing it then it must be OK for me to do it too" when their amp/gear/power situation may differ from yours.
- 908ssp
As long as you turn the voltage down Variacs are not a problem but I don't think they are a solution for the OP's question.
I say change your speakers. Yes that is going to cost and your budget speakers may be the reason for your problem. Reissue greenbacks are way brighter and harsher than pre-rolas and I don't think Stan Specs stand up to comparison with Scumbacks.
flemingmras, i agree with you and understand your concern, however keep in mind wall volts are known to constantly rise above 120.
125-126 range is very common at times and this is dangerous to older amps especially those that are already biased at 70% at 120 volts, which is why i tell folks to NOT bias at 70%,especially older amps.
This is one of the main reasons i use a variac.
Adidas Outlet
Nike Factory
Adidas NMD
Jordans 14
Adidas Outlet
Kids Jordans
Pandora Charms
Jordans 28
NFL Gear
Cheap Nike Shoes From China
Nike Zoom
Christian Louboutin
Air Jordan 33
Jordan 24
Nike Women's Shoes
New Jordans
Nike Jordans
Nike Huaraches
Jordan 25
Nike Air Max 270
Nike Shoes
Fjallraven
Jordan Shoes
Red Bottom Shoes
Air Max 2019
Nike React
Jordan 21
Air Jordan 20
Wholesale Jordans
Nike Blazers
Nike Shoes Canada
Nike Air Force
Nike x Off White
Jordan 11
Nike Jordan 1
Nike Outlet
Nike Acg Shoes
Cheap Jordans
Nike Air Max 720
Adidas Shoes
NHL Shop
Nike Clearance
Pandora Bracelet Charms
Jordans 32
MLB Jerseys
Pandora Charms
Air Jordan 13
Jordan Retro
Nike Air Max 720
Jordan 35
Nike Store
Jordan 12
Nike Air Zoom
Jordans 26
Jordan Retros
Nike Outlet
Pandora Jewelry
Wholesale Jordans From China Factory
Cheap NFL Jerseys
Jordans 19
Cheap Nike Shoes
Air Jordan 5 What The
Adidas Shoes Canada
AJ 1
Jordans 23
Christian Louboutin Shoes
Nike Air Force Ones
Nike Wholesale
Nike Sneakers For Men
Nike Metcon
Nike Air Max 270 Flyknit
Nike Outlet Store
Jordan 34
Wholesale Nike Shoes
Pandora Jewelry
Cheap Shoes
Jordan 1
Cheap Jordan Shoes Supplier
Nike Air Force 1 High
Adidas Yeezy
Nike Shoes For Mens
Nike Running Shoes For Women
Wholesale Adidas Sneakers
Nikes
New Nikes
Nike Air Foamposite One
Jordan 27
Nike SB
Jordan 18
Air Jordan 33
Air Jordan 11 Retro
Jordan 15
Jordan 33 Shoes
Jordan 12 Retro
Nike Black Friday Deals
Hockey Jerseys
Wholesale Cheap Jordans
Adidas Yeezy Boost 350 V2
Cheap Jordans Wholesale
Nike Shoes Sale
Jordan 16
Jordans 29
Nike Outlet
MLB Shop Canada
Jordan Retro 4
Adidas Wholesale Distributor
Lebron James Sneakers
Nike Wholesale
Jordan 17
Nike Running Shoes
Dior Jordan
Jordan 31
Pandora Rings
Jordan 11
Jordan 11 Low
Pandora Jewelry Official Site
Cheap Jordans
Nike Blazer Low
Nike Air Force 1
Wholesale Jerseys China
Air Force 1s
Nike Outlet Store
Jordan 6s
Air Max 97
Nikes Shoes
Jordan 22
Nike Wholesale Suppliers
Jordan 30
Raptors Jersey
Nike Sandals
Nike Outlet Store
Cheap Wholesale Nike Shoes And Clothing
Nike Huarache Men
Air Jordan Shoes
Nike Sneakers
Jordan 12
Nike Cortez Men
Pandora Jewelry 70% off Clearance
Nike Free Rn
Nike Air Max Women
Jordans 13
Wholesale Nike Blazers
Toddler Jordan
Cheap Adidas
Pandora Jewelry
Nike Outlet Store
Pandora Ring
Jordan 2s
Huaraches Shoes
Nike Factory
Adidas NMD
Jordans 14
Adidas Outlet
Kids Jordans
Pandora Charms
Jordans 28
NFL Gear
Nike Zoom
Christian Louboutin
Air Jordan 33
Jordan 24
Nike Women's Shoes
New Jordans
Nike Jordans
Nike Huaraches
Jordan 25
Nike Air Max 270
Nike Shoes
Fjallraven
Jordan Shoes
Red Bottom Shoes
Air Max 2019
Nike React
Jordan 21
Air Jordan 20
Wholesale Jordans
Nike Blazers
Nike Shoes Canada
Nike Air Force
Nike x Off White
Jordan 11
Nike Jordan 1
Nike Outlet
Nike Acg Shoes
Cheap Jordans
Nike Air Max 720
Adidas Shoes
NHL Shop
Nike Clearance
Jordans 32
MLB Jerseys
Pandora Charms
Air Jordan 13
Jordan Retro
Nike Air Max 720
Jordan 35
Nike Store
Jordan 12
Nike Air Zoom
Jordans 26
Jordan Retros
Nike Outlet
Pandora Jewelry
Cheap NFL Jerseys
Jordans 19
Cheap Nike Shoes
Adidas Shoes Canada
AJ 1
Jordans 23
Nike Air Force Ones
Nike Wholesale
Nike Metcon
Nike Outlet Store
Jordan 34
Pandora Jewelry
Cheap Shoes
Jordan 1
Adidas Yeezy
Nike Shoes For Mens
Nikes
New Nikes
Jordan 27
Nike SB
Jordan 18
Air Jordan 33
Air Jordan 11 Retro
Jordan 15
Jordan 33 Shoes
Jordan 12 Retro
Hockey Jerseys
Nike Shoes Sale
Jordan 16
Jordans 29
Nike Outlet
MLB Shop Canada
Jordan Retro 4
Nike Wholesale
Jordan 17
Nike Running Shoes
Dior Jordan
Jordan 31
Pandora Rings
Jordan 11
Jordan 11 Low
Cheap Jordans
Nike Blazer Low
Nike Air Force 1
Air Force 1s
Nike Outlet Store
Jordan 6s
Air Max 97
Nikes Shoes
Jordan 22
Jordan 30
Raptors Jersey
Nike Sandals
Nike Outlet Store
Nike Huarache Men
Air Jordan Shoes
Nike Sneakers
Jordan 12
Nike Cortez Men
Nike Free Rn
Nike Air Max Women
Jordans 13
Toddler Jordan
Cheap Adidas
Pandora Jewelry
Nike Outlet Store
Pandora Ring
Jordan 2s
Huaraches Shoes
