Post
by lautmaschine » Mon Mar 04, 2013 11:14 am
Agree with JDW3. Solodallas has experimented with this sound significantly and concluded that Angus most likely used 70s Super Leads on key albums, such as Back in Black. To get my 1987 in this territory, I did some of the same mods as mentioned above, such as increasing the preamp voltage. I built my 1987 to George's '68 specs, but have now remove the .68 on v2 and changing the coupling off v1b to .0022. I haven't fiddled with NFB yet, so I'm still using the older spec 47k.
A large bright cap is key. I originally built mine with 500pf and found it too harsh, so have been playing with a 100pf for months. But I can't couldn't the right 'jangle' in the rhythm. I've now been experimenting with values of 1000pf to 3300pf (I'm ordering a 4700), and that makes a huge difference in getting Angus' sound--I didn't expect 1000pf to be less harsh than 500pf but it is. On my amp, I have the volume set around 5, and I back off on my guitar volume to 7, and I'm pretty much there for rhythm.
I also agree with the above comments on pickups. A5 magnets are important. I bought a used 490R and change it to an Alnico 5 in the bridge to get that tight sound. I've also ordered some 500k pots to replace the 300ks currently in my SG.
