50 watter blowing mains fuse
- Guitar Adjuster
Just finished it and it's blowing the mains when switched on with or without tubes. The PT is a Mercury Axiom P455JT-G2 and I was not sure if I wired it correctly.
- chubs
If it's blowing the main fuses without tubes you have a short somewhere.
Is this in standby? Is so might be the HV taps that have a short somewhere.
I would:
1- make sure you drain the caps.
2- retrace the whole circuit with the layout next to you.
Use a highlighter and highlite every part oyu check.
Odds are you will find it. If not, go away for a half-hour and come back.
Are you using Slow-Blo fuses? I have had that problem with non-slow-blo.
I would:
- Guitar Adjuster
- Guitar Adjuster
- Guitar Adjuster
Thanks to Steve (SDM) I found out the problem. I was using a SPST standby switch and when I turned on the power it was shorting out the high voltage taps (two twisted blue wires) so in order to correct the problem I have 2 choices, 1. Dump the SPST toggle (carling) switch and go with a regular plexi style switch or 2. Wire the standy similar to a JTM 45 were the high voltage off the PT goes directly to the diodes and the blue wire coming off the cap can goes to the switch on one side and directly to the diode on the other with a jumper from the diode to the bias circuit. So, if anyone else is planning on building a 50 watt plexi take note!!!!!
It's easy for me to be wise after the eventGuitar Adjuster wrote:Thanks to Steve (SDM) I found out the problem. I was using a SPST standby switch and when I turned on the power it was shorting out the high voltage taps (two twisted blue wires) so in order to correct the problem I have 2 choices, 1. Dump the SPST toggle (carling) switch and go with a regular plexi style switch or 2. Wire the standy similar to a JTM 45 were the high voltage off the PT goes directly to the diodes and the blue wire coming off the cap can goes to the switch on one side and directly to the diode on the other with a jumper from the diode to the bias circuit. So, if anyone else is planning on building a 50 watt plexi take note!!!!!
Well done.
It's a horrible feeling when things dont work and you end up pulling all your handiwork apart to fix it - ususally in a rush, often late at night!
You will, of course, have to build another one now...............
- Guitar Adjuster
- Guitar Adjuster
- Guitar Adjuster
- Guitar Adjuster
Ok, got the new "plexi" style main and standby switches installed, it biased up to 35ma with a B+ of 440, take off standby and hit the strings and a loud crackling sound? It you play the strings lightly no crackling but once you hit the strings it makes that horrible crackling sound. Power down, check all wiring, re-solder and touch up almost everything on the board including ground and the same thing happens????? Any ideas, photo's at the beginning of the post. I also switched out tubes including pre's and same thing.
Allen
Allen
