bias supply dropping resistor
- leleduke
Why does the 50 watt instructions call for a 150K? I guess it depends on the trim pot value.
Les Paul Forum member Mark E. Duke <<><
http://www.myspace.com/transitbr" onclick="window.open(this.href);return false;
- Lou
I use 220K on my amp
Lou
Toronto Canada
Metro 1959 X 2; Metro 1987 x 2 ; Metro JTM45; Metro '68 12xxx x 2;Metro 412 Slant 12M Heritage
1980 Gibson Heritage Elite WCR Pickups; 1980 JVSquire Strat; G&L Legacy ; Metro 412 Slant G12M Heritage
www.houseofnot.com
Toronto Canada
www.houseofnot.com
- metalhead3ecr
Re: bias supply dropping resistor
sorry for the bump. But can anyone explain this to me? Thanks!
ac comes from the HT supply it has the resistor before the diode to protect it and keep bias voltage in correct range for your bias pot.
Original 50w using the Drake 1202-118 PT used 220k, earlier PT equipped 45s used 180k. No idea why the instructions say 150k !!
- metalhead3ecr
Thanks! I have a 150K in my 50watt which allows less voltage than a 220K would let in?
V=RI right?
V=RI right?
