50w Bass Spec works now!!!... But it's noisy :(
Danhalen
Post by Danhalen » Tue Dec 01, 2009 12:38 pm
Well it's been a long journey, but after swapping out my PT the amp works! Thanks for everyone's help, both direct and indirect (by using the search function). Also a big thanks to the Metro guys for their help as well.
I think I have a loose connection/ground somewhere though because it is quite noisy. With nothing plugged into the amp, and volume up there is a LOUD hum and even a little bit of radio signal!
Man it sounds good though, even without any break-in it already kicks! But yeah I'm going to do the ol' chopstick trick and try and find any bad solder joints or loose grounds. Could it be a tube as well? Any suggestions?
wildebassman
Re: 50w Bass Spec works now!!!... But it's noisy :(
Post by wildebassman » Tue Dec 01, 2009 1:47 pm
Danhalen wrote:Well it's been a long journey, but after swapping out my PT the amp works! Thanks for everyone's help, both direct and indirect (by using the search function). Also a big thanks to the Metro guys for their help as well.
Did you do all the readings as suggested in the testing section?
If you didn't find any abnormalities it could be a grounding issue or even a bad tube, start at V1.
Cheers,
Dennis.
Amps: JTM 45, JTM 50, under construction: JCM 2204. CAB: 2x12" G12H 30 55Hz. Heritage.
Danhalen
Post by Danhalen » Fri Dec 11, 2009 2:51 pm
Hey guys. Well I took out the chassis, fired up the amp and moved some wires around with a stick. No difference. Still loud buzz. I tapped on some solder connections and got a bit of sound from a couple. Does this even mean anything?
Danhalen
Post by Danhalen » Thu Dec 17, 2009 6:52 pm
Turned out that my Presence pot was a little loose internally. I squeezed it with pliers and it's a lot better now. The amp does hiss more than I would like. My tech friend the level of noise I have is normal for this type of amp. I guess on my next build I'll try the Larry grounding scheme...
Noise aside, the amp is pretty broken in now, I kick started it by playing music through it for 36 hours straight (using my attenuator to control the level when I was home and make it silent when I wasn't or sleeping!). Man it is starting to sound good now!!!!!!! 8)
