I've tried that, the first nut is still very loose and in the picture I'm pushing it up as far as it'll go in the little chassis hole/slot. I've even tried squeezing the mount closed without the Cap in to see if it will go any further, but no such luck for me!axeman wrote:Loosen the nut put second nut in and then align. Let me know.
Art
Well I feel like an idiot, to fix my problem I just installed the mount first, then pushed the Cap Can through the mount after loosening the clamp (instead of trying to install the mount with the Can already in it). It was a little bit of a squeeze but now it seems to fit in there just fine. Thanks for the help!axeman wrote:Push a filter cap in to open the clamp.
