hi all
i have a 50watt plexi kit that i changed to 2204 specs as per sdm,s layouts. it has 50-50 mains cap, 32-32 pi & screens & 33-33 preamp. was thinking of changing the screens cap to a 50-50 to give it a try, would this help tighten the bottom end up a bit. also has 0.1 pi caps in at the moment.
2204 filtering
Re: 2204 filtering
I would replace the PI caps first, personally, 0.033/0.039 or 0.047 depending on what is easily available, then 0.022 as per stock.
There is not a lot of difference between 32 and 50 on screens and PI
