Mercury Magnetics PT Question
Posted: Thu Feb 11, 2010 11:57 pm
My first real question here will unfortunately expose how little I really know about this stuff but please take it easy on me. I opted for the MM Power Transformer (shown below ) it came with a schematic (also shown ) but the terminals were not numbered. Could someone check and see if I have this correct so I don't blow myself up.
Com To Fuse Holder Side Terminal
6 To “AC” Terminal of Bridge Rectifier
7 To Ground Lug on F1 then Neg terminal
8 To “AC” Terminal of Bridge Rectifier
9 To V5 Pin 7 – Heater Wire 3.15 Volts
10 To Ground Lug on F1
11 To V5 Pin 2 – Heater Wire 3.15 Volts
12 Not Used?
13 Not Used?
Black Wire From Primary to power switch (120 Volts)
Also no wire came with this should I buy same as heater wire (22 guage 600 volt?)
Thank you for your help
12 Not Used?
13 Not Used?
