Black Flag ( My version )
Posted: Thu Mar 04, 2010 10:22 am
by myfoot
Took me about a year to source parts and decide what I wanted to do with this. Started out with a regular JTM50 board from BrianH here but decided I already had done one of those already so I got some turrets and added a couple and ended up with a 50 watt lead with a tube rectifier.
Ceriatone chassis , marstran transformers ( almost put the dual voltage switch in (bought one ) but decided there just wasn't enough room to squeeze it in. BrianH's board and tag strip I had him make for me to use for the 5 voltage taps on the Marstran transformer
Of course using that I had to move the fuse to the back panel so I have one of his fancy fuse holders for my next build :D
Kind of crowded on that side with the rectifieer wiring
Had enough wire on the output primary to run around the socket and away from the secondaries . I was going to use my set of Sozo vintage on this one but I would have had to order some more 022s and had enough 018s and some .68s so I figured what the hell :)
One bug I had with using the pink wire ; I had the wiper of the treble and mid pots reversed :oops: didn't take to long to figure out something wasn't right .
Re: Black Flag ( My version )
Posted: Wed Mar 10, 2010 3:58 pm
Looks like a raunchy Black Flag to me 8) .
Posted: Thu Mar 18, 2010 10:34 am
by arledgsc
Awesome! My next amp is going to be a Black Flag bass spec. Scoring parts now. Thanks for the inspiration and nice build! Scott
Posted: Sun Mar 21, 2010 8:30 pm
by ThunderOne
Congratulations on this fine build! Did you polish the inside of the chassis? It sure looks like it from the pics... :D Your choice of components is first class too.
Posted: Fri Apr 16, 2010 11:28 am
by Big Mike
Badass!!!
Posted: Fri Apr 16, 2010 1:32 pm
by MacGaden
Are you still building for your son ? I´m still up for adoption... :wink:
Beautiful build as always..
Posted: Fri Apr 16, 2010 2:21 pm
by myfoot
MacGaden wrote:Are you still building for your son ? I´m still up for adoption... :wink:
Thanks... . Yep still building for the son... be cheaper for me to take up guitar playing :D ( maybe )
Got the boards done for a Dickinson 45/100 . Now I need the chassis and transformers and the assorted other things. Waiting to hear from Brian (Wallace) when the OT is in stock and then I can get my Metro order in.
Posted: Fri Apr 16, 2010 2:36 pm
by MacGaden
Can I come live in your basement just to break it in ?
Posted: Fri Apr 16, 2010 3:31 pm
by myfoot
Well you could but your commute to work would be a killer :D
