TheFullNelsons
Post
by TheFullNelsons » Sat Mar 06, 2010 3:33 pm
TheFullNelsons on Fri Sep 10, 2010 8:18 am, edited 2 times in total.
laneychris
Post
by laneychris » Sat Mar 06, 2010 3:43 pm
I just put a duet of seimens 34's today and my B+ was 450.. and yes my bias pot was maxed to add I had -34 on one tube and -33 on the other
mine is maxed also..I almost forgot nice job!
eddie25
Post
by eddie25 » Sun Mar 07, 2010 7:41 pm
Put a 33K in place of the 47K in the bias circuit and it should have a better range. Every plexi style amp I've built needed a 33K, I just do it right off the bat now.
syscokid
Post
by syscokid » Sun Mar 07, 2010 9:55 pm
eddie25 wrote:Put a 33K in place of the 47K in the bias circuit and it should have a better range.
Agree...
I used a 36K.....It was the next-smallest resistor I had laying around. The bias trim pot is now in the middle of its range when setting the bias in the mid 30's.
TheFullNelsons
Post
by TheFullNelsons » Mon Mar 08, 2010 9:55 am
syscokid wrote:eddie25 wrote:Put a 33K in place of the 47K in the bias circuit and it should have a better range.
Agree...
Thanks for the reply... I thought that may be the solution. Played the amp all weekend...I am really suprised at how nice this amp sounds clean (easy to find the sweet spot where it's clean when played lightly then digs in when you pick harder). I can't imagine this amp without the PPIMV as I have never had a louder amp ( this thing seems twice as loud as the 100W Mesa Roadster I had).
The only problem I have so far is a brutal ground loop when I use my TC G System in the effects loop. It sounds great and very transparent with just a pedal in the loop so just a ground loop problem.. This amp loves pedals in front..especially my BB Preamp....
arledgsc
Post
by arledgsc » Tue Mar 09, 2010 9:59 am
have one question about the bias setting. As you can see from the PDF below the V4 reading was 36.0 and the V5 reading was 34.0 even with the pot fully counterclockwise...is this a problem (bias slightly cold).
Congrats on finally getting your 50 watter up and running. I had the same issue with cold bias. The kit instructions call for a 150k ohm main bias voltage dropping resistor before the diode. Change this to 220k ohm like shown in the schematic in back of the assembly instructions. You should have a 220k ohm in your resistor kit. It will dial right in afterward.
Metro JTM45, Metro 50W Lead, JTM50 Black Flag, and Ceriatone 18W TMB
Scumback M55/M75, Ceriatone C-lator
TheFullNelsons
Post
by TheFullNelsons » Wed Apr 07, 2010 5:34 pm
arledgsc wrote: have one question about the bias setting. As you can see from the PDF below the V4 reading was 36.0 and the V5 reading was 34.0 even with the pot fully counterclockwise...is this a problem (bias slightly cold).
Thanks... the 220K worked like a charm
Arclight
Post
by Arclight » Sat Aug 21, 2010 8:46 pm
Thanks-I finished my 50 watt build and was only able to get my NOS xf2's to 36.6/35.0 @ 436vac. I wasn't sure if the 47K resistor across the bias pot or the 150K before the diode was the solution.
Metro JTM 45, Metro 1987, Reeves Custom Lead, Carr Mercury,Carr Hammerhead,Emery Sound Superbaby. Hoarder of NOS tubes!
