Here's a picture of the insides of my MetroAmp before I installed the power cable. In this picture there is actually one resistor that is wrong that I didn't find out until after I brought it into the local amp guru to get the voltages checked up and the amp tested. It's next to the gigantic black capacitor in a group of three resistors hooked up to one terminal. The middle one was supposed to be a 470 Ohm resistor and I had accidentally put in a 47K Ohm resistor. Woops! After my tech installed a NOS Allen Bradley 470 Ohm resistor, she now sounds beautiful. I LOVE THIS AMP! THANK YOU SO MUCH METROAMP!!!
As my tech noted, and it is true, the bright channel on this thing is TOO bright. So I'll be throwing a 250 cap in there at some point once the amp gets more "burned in".
Now all I want to do is BUILD MORE muahaha
