Stringseperation on JMP 50 plexi
Posted: Wed Jul 14, 2010 5:22 pm
by mary04
Any suggestions on how to get a more stringseparated distorted tone on my 50 watt plexi? My main guitar is a Gibson LP with Lollar Imperials. Play through a D13 2x12 cab carrying greenbacks. Also use Weber Mass 150 attenuator. The rack is pure rock`n roll with a very nice classic distorted plexi tone. But if it`s possible, I would have liked some more stringseparation in the overdriven tones. I`ve heard swapping to certian tubes in V2 could help me with this. Glad for all suggestions and opinions.
Mary
Re: Stringseperation on JMP 50 plexi
Posted: Thu Jul 15, 2010 3:49 pm
by Roe
- high voltage
- kt88s/6550s
- choke with 7-10+ hendries
Posted: Fri Jul 16, 2010 9:11 am
by demonufo
Roe wrote:- high voltage
- kt88s/6550s
+1
Especially the 6550 suggestion.
Not sure you'd have much luck changing by V2 though. Now a lower gain tube in V3 (5751 perhaps) might be the ticket.
Posted: Thu Jul 22, 2010 11:20 am
by mary04
Thanx!
Gonna try that V3 move first!
Mary
Posted: Thu Jul 22, 2010 2:10 pm
by demonufo
It should work but you may have slightly less gain.
Posted: Thu Jul 22, 2010 5:51 pm
by Roe
try a 12at7 in v3
Posted: Thu Jul 22, 2010 5:58 pm
by SteadyEddie
I've been checking out this thread and thinking about trying this on my amp when I get back from offshore:
http://forum.metroamp.com/viewtopic.php ... &sk=t&sd=a" onclick="window.open(this.href);return false;
I'm also considering KT66's, I have a couple in my Super Reverb that I want to try out in the old plexi. I understand they're less compressed and grainy than the EL34's.
Posted: Thu Jul 22, 2010 9:42 pm
by OnTheFritz
You could also try removing the V2A cathode cap.
I would try that before swapping in different power tubes.
Posted: Thu Jul 22, 2010 10:08 pm
by SteadyEddie
Yeah, the V2A cathode cap, that's the post I was referring to earlier.
I've been wanting to try that. I'd like my amp to clean up better with the volume knob.
Posted: Fri Jul 23, 2010 2:27 pm
by mary04
Roe wrote:try a 12at7 in v3
Just did! Sucsess!! The swap didn`t make a huge different, but slightly enough to make me happy. And thank god for that, because the other, more technical suggestions you good people gave me, I didn`t understand one bit off! I`m impressed with the level of knownledge upon you guys. Really I am.
Thank you!
Cheers
Mary
Roe - vi må vel kanskje treffes snart sånn at du får tatt en justering på Metroen min som vi snakket om ifjor?
Posted: Fri Jul 23, 2010 3:02 pm
by Roe
mary04 wrote:...
gjerne det, bare send en melding. jeg er stort sett i tr. heim
Posted: Tue Oct 05, 2010 2:50 pm
by awangotango
the other factor is that lollar paf . It's soft, fat and contributing to your lack of 'string separation'. At least the one I used to own sounded that way.
