50 watt Chassis?
50 watt Chassis?
Hello to all, I have been away for some time and just starting a 50watt Marshall style build that I have had most parts saved,the item I need is a Chassis, I see the Metro store is not listing the ones they had,50w steel type, is this not available any longer? or is it a special order? can someone update me please, thank you, Bluze
Re: 50 watt Chassis?
I believe if you check with Brian Wallace at Marstran he has some extra's from a run he did. Valvestorm.com has panels and may know where to get a chassis. Or Ceriatone has both chassis and panel.
Good luck!
Good luck!
Thanks for the reply, In other words Metro has no 50w steel chassis, I have done business with Brain at Marstran, So thank you, Bluze
