JMP50 68-69' specs (work in progress...)
Re: JMP50 68-69' specs (work in progress...)
Post by Roe » Mon Oct 01, 2012 2:16 pm
Coot Boy wrote:Doesn't tying your OT primary and secondary wires together create some kind o noise/hum? Sure I read that somewhere.
you risk oscillation and redplating
leonard.gulyas
Post by leonard.gulyas » Mon Oct 01, 2012 11:19 pm
Dear Roe,
Can you please explain to me what are these terms and what they cause in terms of sound/operation.
Regards
Post by Roe » Tue Oct 02, 2012 4:58 am
Dear Roe,
Regards
sorry, try to search and to read
Post by Roe » Tue Oct 02, 2012 3:51 pm
Dear Roe,
Regards
sorry perhaps this will help:http://forum.metroamp.com/viewtopic.php ... oscilation
http://forum.metroamp.com/viewtopic.php?f=4&t=16511
leonard.gulyas
Post by leonard.gulyas » Tue Oct 02, 2012 4:59 pm
Thanks Roe for the links.
So how much distance between OT input and output cables is adequate?
Regards
leonard.gulyas
Post by leonard.gulyas » Wed Jan 23, 2013 5:36 pm
So the build continues after the turret board finally arrived (after 3 months :) ).
As Roe and others suggested I untied the OT Primary and Secondaries to avoid further problems.
I installed the HT Fuse (internal one due to lack of real estate).
I cabled the turret board as the kit instruction suggested.
I did a fit test with the turret board, so here it is:
I'll keep you posted as the build continues tomorrow.
leonard.gulyas
Post by leonard.gulyas » Thu Jan 24, 2013 6:08 pm
Updates:
I changed the cable routing thru the turret board as I noticed that is the way others do with this type of board.
I also arranged the cables to their places, can somebody please check if there is any overlapping cables can cause some problems because there is so many of them :) ?
Regards
julkke
Post by julkke » Fri Jan 25, 2013 12:08 am
Super clean work so far, candy to the eyes!!
Post by Roe » Fri Jan 25, 2013 5:17 am
leonard.gulyas wrote:Updates:
Image[/url]
Regards
I'd minimize parallell wires, esp. the green and blue ones in the preamp and the primary and secondary of the OT
BrianH
Post by BrianH » Fri Jan 25, 2013 3:29 pm
Sorry it took so long, Leonard! Your address changing, board being returned to me, and then a Customs delay really made it rough.
leonard.gulyas
Post by leonard.gulyas » Fri Jan 25, 2013 4:52 pm
I really have to say Brian it worth the wait and you are a super nice guy to deal with.
axeman
Post by axeman » Sun Jan 27, 2013 9:19 pm
Wow, it is turning out very nice. Good job. We're did you get the switches? I would like to use some of those on my next builds.
Art
leonard.gulyas
Post by leonard.gulyas » Thu Jan 31, 2013 8:37 pm
Thanks for the kind words, I PM'd you about the switches.
