metalhead3ecr
Post
by metalhead3ecr » Wed Nov 14, 2012 12:08 am
This is my first build. I bought the chassis from triode...it is intended for a 100watt. I am trying to make a Curt Mitchell Langner amp with a PPIMV. Advice and comments are welcomed!
-Ed
- Front of Amp
- (137.84 KiB) Downloaded 1196 times
- Board assembly
- (235.15 KiB) Downloaded 1196 times
- Heater wiring
- (153.67 KiB) Downloaded 1196 times
julkke
Post
by julkke » Thu Nov 15, 2012 8:17 am
Why did you leave the first preamp tubes heater wires untwisted? Otherwise looking good.
metalhead3ecr
Post
by metalhead3ecr » Thu Nov 15, 2012 9:10 am
Good Question! I actually do not know the math behind it...but if you go to Curt Mitchell's site, you can see that Langner left them untwisted on his amp too....so I just copied Langner's wiring. I don't know if it is done on purpose or just lazy
Here it is.
- (257.65 KiB) Downloaded 1162 times
julkke
Post
by julkke » Thu Nov 15, 2012 9:57 am
Yeah I think you can get away with it but if you have hum issues when you finish it you better suspect those untwisted heaters. I'd twist them now when it still is easy. You've done great heaters, do the icing on the cake now.
metalhead3ecr
Post
by metalhead3ecr » Thu Nov 15, 2012 10:54 am
seems logical! I will twist them up this weekend. All that is left to do is hook up the power indicator, fuses, and power inlet, then connect the PTP board and bias the thing. Hopefully she will make some type of noise this weekend!
julkke
Post
by julkke » Thu Nov 15, 2012 1:08 pm
One thing I just noticed is that you are going to put the ppimv to input jack hole. That won't work. It will oscillate, even if you use shielded wire. Put it to one of your speaker jack holes OR the indicator light hole.
julkke on Thu Nov 15, 2012 1:16 pm, edited 1 time in total.
metalhead3ecr
Post
by metalhead3ecr » Thu Nov 15, 2012 1:14 pm
Alright. I will try to find a better location for it! thanks
julkke
Post
by julkke » Thu Nov 15, 2012 1:15 pm
Oh and also, twist your OT secondarys together (the wires going to the impedance switch).
metalhead3ecr
Post
by metalhead3ecr » Thu Nov 15, 2012 7:54 pm
Yea I was wondering about that. Ok will do! Thanks
I will keep you updated on the build!
