I would like to ask your help in my new build.
The specs are the following:
50W
1986 bass spec
Marstran 1202-118 PT
Marstran 784-139 OT
Marstran C1999 Choke
Larry star grounding
everything else is according to the kit instructions
The problem is I can't get the required -20 ~ -50 VDC interval for the negative bias supply. I can only get -14VDC when the bias pot is on max and -12VDC when is on minimal. The wall voltage is around 236V so the voltage selector is set to 240V.
Here are the initial voltage reading for Testing Part1: Powering up:
Here are some more pictures for troubleshooting.
Thanks in advance.
Regards
