50w plexi 1987 master volume mod TEMPLATE
Posted: Sun Aug 04, 2013 1:00 pm
by frusciante89
Hey guys, I want to build a 50w 1987 with a master volume mod... Unfortunately I didn't find any template "off the shelf" so i decided to open solidworks and draw mine... I'm sharing the file, let me know if the space organization makes sense
Re: 50w plexi 1987 master volume mod TEMPLATE
Posted: Sun Aug 04, 2013 9:22 pm
The guy that put the Lar-Mar recommends that you do not put the pot so close to the inputs to avoid crosstalk. I have put one in the presence spot and in the trem control hole without issues. You may get away with it with good lead dress and shilding but you may not - which makes your dedicated chassis a bit redundant. Putting it at the other end (near the pesence pot etc also keeps the shielded wires much shorter keeping the capacitance (and potential rolling off of highs) lower.
Posted: Tue Nov 19, 2013 4:59 pm
by Ed Chambley
I normally just use the ext speaker, but have drilled a hole on back of a build (not a original). Although, I do not change the master often. I find from the back it is most quiet and as was said, the lead dress is very short and I can keep it above everything. I also only use PEC dual pots and shielded wire. I know some who have gotten away with twisting, but shield just works better.
Posted: Thu Jan 16, 2014 11:38 pm
by Peter_006
Nice post!
Posted: Thu Feb 13, 2014 6:03 am
Well the SPAMMERS are still finding their way in, hope viruses and malware not as well
Posted: Wed Mar 12, 2014 3:05 am
by frusciante89
are you referring to the file I uploaded?
Posted: Wed Mar 12, 2014 3:54 am
frusciante89 wrote:are you referring to the file I uploaded?
No, to Peter_006 flogging his storage facility!
Posted: Thu Mar 13, 2014 5:29 am
by rgorke
neikeel wrote:frusciante89 wrote:are you referring to the file I uploaded?
How did/do you know that?
Posted: Thu Mar 13, 2014 9:06 am
rgorke wrote:neikeel wrote:frusciante89 wrote:are you referring to the file I uploaded?
The post made no sense and look at his other post it is spamming properly!
